Check engine light
Old Feb 14, 2009 | 10:42 AM
stevey88's Avatar
Default Check engine light
Mine is a 99 RR and I have never seen the Check Engine light come on. Are all the warning lights suppose to be on when you turn the key to position II and the lights will go out one the engine is started and the car is moving ? I have hooked a OBD II test to the car car and it said MIL is off. My other cars will turn on the Check Engine light once the OBD tester is hooked up.
Thanks.
Old Feb 14, 2009 | 10:45 AM
rr95's Avatar
If your scanner is showing "MIL lamp off" and not showing any fault codes, i'd suspect a blown out bulb. Easy enough to replace.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
