climate control and radio on fritz.
Old Dec 23, 2007 | 05:31 PM
the.nation.needs's Avatar
Default climate control and radio on fritz.
I have a 1997 4.6 HSE that's developed an issue with both the climate control and the radio. They were working fine earlier in the day but after a brief stop for groceries they failed to come back on.
This happened once before a month or two ago but the next day it worked fine. It's been several days now with no such luck.
The climate control back light comes on but no characters show up on the screen and the controls have no effect. There's no heat whatsoever and, well, it's getting cold up here in Northern Idaho.
The radio just fails to work at all. The code light was blinking but has since stopped. Pushing the power button does not bring up the "enter code" option.
Any thoughts would be welcome before I take it into the shop. Thanks for the help.
Old Dec 23, 2007 | 05:41 PM
sideburns's Avatar
Default RE: climate control and radio on fritz.
relay 7 on the engine compartment fuse box is not grounding,you can trace this back to a malfunction in the body electrical control module or becm,just worked on a car with the exact symtoms
Old Dec 24, 2007 | 02:16 PM
Thank you very much for your help. I'll pass that along to the mechanic.
Green Blood
Dec 22, 2018 04:40 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
mdf27
Feb 17, 2008 02:35 PM
jasonsLR
Sep 3, 2005 02:39 PM
dbs600
Jul 11, 2005 08:44 PM
