Disconnecting fuel rail
I am doing a head gasket replacement and the strip down come to the point that I need to disconnect the fuel rail from its supply. I tried to press down the tap and pull the connection off but it did not move. The tap is flush with the surface of the plastic connector so it does not press down a lot. Please see attached photo. What is the trick ? Is there another press tap at the bottom ?
Edit: No release tool needed, that would have made it too easy.
JumPeR04
04-07-2011 09:52 PM
JumPeR04
04-01-2011 04:15 PM
