Disconnecting fuel rail
I am doing a head gasket replacement and the strip down come to the point that I need to disconnect the fuel rail from its supply. I tried to press down the tap and pull the connection off but it did not move. The tap is flush with the surface of the plastic connector so it does not press down a lot. Please see attached photo. What is the trick ? Is there another press tap at the bottom ?
IMHO there would be another press tap, maybe slide an inspection mirror under it. Or it may be like Fords and have a clamp on tool that goes around the pipe and slides into the connector.
Edit: No release tool needed, that would have made it too easy.
Success!! I removed the bolts for the lower inlet manifold so I can move it forward a little, put a wood shim under the rear of it. Now I can put both of my hands there. One to press the two taps and the other push the quick connect back.
Thanks again for the help.
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
