Driver Side Mirror Controls
Old May 12, 2013 | 10:54 AM
nycranger's Avatar
8th Gear
Default Driver Side Mirror Controls
Hello All,
I have a 2006 Range Rover which had a driver side door actuator issue (keyfob wasnt working on the driver side door). I bought a door latch on ebay and had a local technician install it which only took about 30 minutes.
My problem now is that the driver side controls that adjust the mirrors is no longer working for the driver mirror. It works for the passenger but not the driver side.
First i thought the technician who installed the latch forgot to connect one of the connectors being the problem started right after he installed the latch. Took the car back to him and he double checked his work and we both saw that all the connectors were properly connected.
Question is, can a blown fuse be causing this problem? I doubt the motor could have stopped working just because the door latch was replaced.
Old May 11, 2016 | 01:15 PM
j8levi's Avatar
Hello,
Did you find out what the problem was and were you able to fix it.
hobiecat
May 28, 2012 11:19 AM
hotelmez
Jul 9, 2008 06:17 PM
03LRSE7
Jan 27, 2008 09:26 PM
morfa
Dec 23, 2007 10:38 AM
Discofan
Nov 30, 2005 10:07 PM
