Engine rattle on start up
Old Jan 29, 2014 | 08:51 AM
Crash_Control's Avatar
6th Gear
Default Engine rattle on start up
I have a 2007 Range Rover Sport Supercharged with the Jag motor .
Engine rattles on start up , I have replaced the timing chains and tensioners and the seals for the VCT where it mounts into the variable gear .
The engine still rattles on start up, I pulled the VCT valves that stick up through the valve cover, and wonder if there are supposed to be seals on these.
This is driving me crazy ( short drive though )
Thanks Ralph
Old Jan 29, 2014 | 08:52 AM
antichrist's Avatar
You've made sure it's definitely the engine, and not the cats?
Old Jan 29, 2014 | 12:47 PM
6th Gear
Seems to be coming from front of engine , directly on start up .
That's why I did the chains and tensioners and noticed the seals were sort of slack .
Old Feb 5, 2014 | 12:55 PM
6th Gear
Replaced the VCT gear and rattle went away .
Old May 29, 2021 | 12:27 AM
JN5LR3's Avatar
Hey there, I am having the same issue on my 09 LR3. ITs only got 60k miles and has just started giving me a rattle on cold starts. Only lasts 1-2 seconds, and only on cold starts. I can feel the VCT solenoid vibrating when it makes the sound. 2 questions for you. FIrst, did replacing the solenoid require special tools? Second, After changing the gear, has the sound returned? Thanks!
Johntom
Dec 10, 2011 11:01 PM
brettmasters26
Nov 25, 2011 07:40 PM
jb0190
Jul 22, 2009 05:22 PM
mortality101
Oct 11, 2008 07:36 AM
rphotographer
Apr 12, 2007 10:13 PM
