Engine Swap Classic RR
Hi Classic fans,
I have read a number of posts and have found them all useful. I am most interested in engine swaps. From the posts I have read most have made a swap or engine rebuild anywhere from 120k to 180k miles. It seems all have the same complaint of lack of power and a want for better fuel economy, better torque and greater power.
My rig is an 89 RR with mega miles on its clock. Miraculously the engine still runs and gives me the same power its 3.9 power plant gave me when I purchased it in 91. I stopped counting the miles after the replacement of the odometer 3 x's and an added accumulation of miles of 450k+ miles. It all boils down to changing the oil every 3k miles and adding ultra lube additives to the crank and transmission oils.
My boy has some issues though I need to do some welding on the body but is nothing I can’t handle. The frame is in great shape. And there is very little rust. The body needs to be repainted all equating to cosmetics not mechanicals.
Okay enough on what I have. Iwould like tochange out the engine as like others I want more torque, cheaper replacement parts, readily available and easy to fine parts (standard), more horsepower and best of all much better fuel economy. The latter is something the 3.9, 4.0 or 4.1 will not give. There are options to add a different LR engine that tend to be gas guzzlers and cost mega bucks.
So the big question has anyone swapped out their old 3.9 and put a Chevy LT1 or LS1 small block in its place. If yes what were the issues? Did you have to modify the engine mounts? Were you able to go directly to the LT230 x-transfer box or did you have to make modifications. Where did you get your wiring harness? I have found Painless Wiring to be a good source.
Any who can shed some light on this subject would be greatly appreciated.
Cheers,
Geoff
Cheers,
Geoff
It is very apparent that no one on this section of the forum, either knows or cares. I have posted other needs with little replies. Disco people are much more helpful, but your question is about a RR. You should post your question om ranagerover.net in the classic section. Good luck
roverfriend
Sep 26, 2010 11:04 PM
Caribbeanrange
Apr 17, 2009 02:24 AM
m3 bavaria
Jul 25, 2007 02:07 PM
02, 2001, chevy, classic, conversion, engine, lt1, ranagerover, range, replacement, rover, swap, transplant, v6
