Engine won’t start
Engine won’t start
Long story short, I went to start the engine and it wouldn’t start, it acted as if the battery was completely dead. No electrical came on. So I charged the battery for a few hours and tried starting it. When I put the key in all the electrical came on. But as soon as I turned the key to start the engine it clicked once and all power shut off like a breaker was switched. I had to unplug and plug the battery back in to get the electrical to come back on, but once I try to start it again the power shuts off.
The positive battery cable was replaced and the battery was checked. Battery is brand new and holds a good charge. But still getting same issue. No start, and no sound from starter. All power completely shuts off as soon as I turn the key.
Any suggestions? Is this a starter issue?
Sounds like something started to become loose and now it's not connected well enough to transfer enough power to start it. I would check all your large power cables that run from the alternator to starter to fuse box etc. and grounds. Look for corrosion too, my old RR had a ground that looked fine but when I split it open it was extremely corroded.
