Engine won’t start
Old Jan 18, 2018 | 04:06 PM
MichaelAllison's Avatar
Default Engine won’t start
Long story short, I went to start the engine and it wouldn’t start, it acted as if the battery was completely dead. No electrical came on. So I charged the battery for a few hours and tried starting it. When I put the key in all the electrical came on. But as soon as I turned the key to start the engine it clicked once and all power shut off like a breaker was switched. I had to unplug and plug the battery back in to get the electrical to come back on, but once I try to start it again the power shuts off.
The positive battery cable was replaced and the battery was checked. Battery is brand new and holds a good charge. But still getting same issue. No start, and no sound from starter. All power completely shuts off as soon as I turn the key.
Any suggestions? Is this a starter issue?
Old Jan 18, 2018 | 04:46 PM
Dave03S's Avatar
What is the year and model of your vehicle?
Old Jan 18, 2018 | 11:23 PM
DiscoCam's Avatar
This is why I think we should have separate sections for RRC, P38, L322, etc...
Just my $0.02
Old Feb 25, 2018 | 07:43 PM
cardude59's Avatar
make sure BOTH battery cables are tight, and by tight I mean tighten the clamps until you think they are tight, then go a half turn more. you should not be able to move them at all by hand or otherwise.
Old Jan 2, 2021 | 04:11 AM
LRScott's Avatar
Sounds like something started to become loose and now it's not connected well enough to transfer enough power to start it. I would check all your large power cables that run from the alternator to starter to fuse box etc. and grounds. Look for corrosion too, my old RR had a ground that looked fine but when I split it open it was extremely corroded.
SundayFunday
Jan 7, 2021 06:00 AM
DavidausStuttgart
Mar 15, 2015 11:07 AM
antb7979
Mar 29, 2011 06:17 PM
hazletbassist89
May 17, 2009 10:14 PM
