heating problem - range rover on lpg
Old Mar 15, 2012 | 11:19 AM
steve4th's Avatar
Default heating problem - range rover on lpg
Hi - Recently bought my rr [4 months ago] and seems there is an issue with the cabin heating - from cold gets up to temperature then seems to cool down whilst running - nothing altered on the controls and engine temp in the ok band. - feels for all the world like an air lock?
Had the air con checked out and all ok in that department, and when you click the air con into active, doesnt seem to alter things - just stays cold.
Suggestions guru's please
Thanks
Old Mar 15, 2012 | 02:38 PM
Low coolant, a large air bubble, or a sticking thermostat could contribute to all of this. Helps to know model year and miles (kms).
Old Mar 16, 2012 | 04:36 AM
steve4th's Avatar
Thanks. It's a 2000 with 110,000 miles on the clock. Runs on lpg. Coolant level is fine and holding. Had the heads done by previous owner (seen receipts)
Old Mar 16, 2012 | 05:18 AM
I'd vote for sticking thermostat. You could attach a scanner or ultra gauge and watch the temps in digital form, and see exactly how it is changing. A stuck open thermostat will show up as warms up, but below nameplate rating for stat, and won't get past the nameplate rating usually. The open stat also changes the water flow in some cases in the heater core.
bristolrange
Dec 16, 2013 02:58 PM
TonyRover
Sep 19, 2013 02:06 PM
spaltring
Dec 16, 2012 09:28 AM
rodwhirity
Mar 7, 2012 07:00 PM
djones70
16
Apr 11, 2008 12:38 PM
