Hello all, new owner of 1995 questions??
Old Sep 5, 2011 | 10:04 AM
Capt. Awesome's Avatar
5th Gear
Wink Hello all, new owner of 1995 questions??
I am a new owner of a 1995 range rover with 3.9 engine,and have heater core I think issues?is the 3.9. The same as 4.0 heater core ? And it is left hand drive so will be attempting to replace or repair ,any help would be great..
Old Sep 5, 2011 | 11:23 AM
EUR Mechaniker's Avatar
if its an se its the same
Old Sep 5, 2011 | 12:11 PM
5th Gear
Then pics of the heat core on this site are what I can use to fix heater core ,and have you ever fixed the leak on one of these ?
Old Sep 5, 2011 | 12:13 PM
5th Gear
Also it's a range rover country classic 3.9l..if that helps here..
Old Sep 5, 2011 | 03:30 PM
Rovin4life's Avatar
completely different heater core compared to a P38.
Old Sep 6, 2011 | 10:07 AM
yes... the classics are different... the theory is the same though... you have to remove the center console, lower and center dash parts, disconnect all ducts and electrical from the heater box, remove the heater box and split the case...
Old Sep 7, 2011 | 08:50 AM
5th Gear
Thank you, but how easy does all this stuff go back in? Cause you know once you mess with it doesn't usually work the same .but I guess th core is fixed!
Old Sep 7, 2011 | 12:51 PM
its usually fairly easy to put a dash back together the way it came apart but i have noticed these vehicle are ery picky about which piece comes out r goes back in in a certain order. the knee panels are particularly difficult especially if someone has been in there before and messed them up (95% of the ones i have taken apart have been previously messed with)
have you already replaced it or did it just stop leaking?
Old Sep 7, 2011 | 12:52 PM
^^^ nvm posted faster than the speed of comprehension
Old Sep 8, 2011 | 10:54 PM
5th Gear
No have not go at the core yet just trying to figure out what to take part, and floor boards are soaked ,so I think it's not the o ring seals but the whole core is shot..
Run33
May 11, 2015 09:43 PM
triguy0220
Nov 5, 2013 09:28 PM
hankmcrae
Oct 23, 2012 05:35 PM
Memphy03
Mar 14, 2007 11:12 AM
IcemanBaldy
Oct 26, 2006 03:43 PM
