Help! The air conditioner blows hot after 15 min...
For some reason, my air conditioner blows hot air after the engine gets warmed up. The temp gauge does not read abnormal and usually rides under the halfway mark. The freon is full as well. It is the original compressor and the car has 75K on it. The compressor used to kick out when the pressure was too high (and the ac was normal), but now it does not kick in or out.
sounds like you have a problem with your compressor control circuit, easiest check is fuse 3 under your hood, if not, you need to start checking different sensors and switches and be sure that youre freon is properly charged
ssblast20
Nov 27, 2014 10:02 PM
mpompliano
Freelander
Jul 31, 2012 06:13 PM
