Horn out of action - can I bypass the relay?
Old Oct 30, 2010 | 05:06 PM
Russian_Rover's Avatar
Default Horn out of action - can I bypass the relay?
Hi everyone!
I had intermittent horn only a couple of months ago before it stopped all together. The shop replaced the relay, and now I have exactly the same issue!
Can I bypass the relay at all or is that too dangerous?
Ordering parts here is not the easiest thing to do! Nor is driving without a horn!
Cheers!
Old Oct 30, 2010 | 05:34 PM
I should have said its a 1998 P38, sorry!
Old Oct 31, 2010 | 08:15 AM
wilson96rr's Avatar
It is probably the rotary coupler on the steering wheel that is the problem. That being said, it would be very easy to just wire up a push-button switch for the horn, with or without a relay. I would not bypass the relay while using the existing steering wheel horn switch. That could cause some really expensive problems. The horn is a pretty simple part of the car.
Old Nov 4, 2010 | 09:44 AM
Thanks for the reply!
I had the rotary coupler replaced already. Then I was having no horn on and off and they replaced the relay, and now I have horn only sometimes again!
I'm wondering if perhaps they wired the rotary coupler in wrong? This is a non genuine dealer but they seem very good...
No idea what to do next really. Going back to the shop on Saturday so will update!
Old Nov 4, 2010 | 06:09 PM
wilson96rr's Avatar
maybe a bad connection somewhere
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
Rover_Mike
Dec 11, 2012 09:21 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
lipadj46
Aug 14, 2009 01:50 AM
