I dont know....
Old Apr 1, 2010 | 04:36 PM
bentonrover's Avatar
Default I dont know....
Just like it says. Did a tune up on my bosch 4.6 plug wires was not as bad as everyone made it out to be. On the last plug when I removed it noticed the hole was stripped. Put the new plug in on a angle almost 3/4 of the way in and it stopped. Still not seated. Truck seems to run good and strong but worried about the plug blowing out. What can I do?
Old Apr 1, 2010 | 05:49 PM
LRScott's Avatar
Found a little article on it for you. If you decide to re-tap it, make sure you do not get any metal shavings in the cylinder. The other option is to replace the whole head of course...
http://www.popularmechanics.com/auto...o/4212608.html
Old Apr 2, 2010 | 12:11 AM
Thanks Scott I did try out that tap set. Its funny cause I used the tap and cut new threads. I put a new plug in and it went pretty much all the way in just not seated all the way. It starts up and drive better than before. Guess I see what happens.
Old Apr 2, 2010 | 12:27 AM
WARWAGON's Avatar
That blows! They do make spark plug thread repair kits. I've helped a guy at work install one on a truck he was working on and it worked pretty good. I was pretty impressed. Same situation cust. brought it in with hole stripped out and he agreed to try and fix it that way, considering the price of taking the head off and sending it out. We used one that was an insert type. It had 3 different sizes, it came with a tap also. After you put it in there is a tool that also comes with it and you hit it with a hammer to seat the insert. Like I said, actually worked real good.
Old Apr 2, 2010 | 01:22 AM
Thanks that's the set I got. Gonna do it right and hit that insert into the hole. Kinda of scared. If that thing falls in than I'm really screwed. Ill let you know how I made out
Old Apr 2, 2010 | 10:43 AM
Well I did it. Still not seated all the way but close. Put the lock tight and a little silicone at the very end by the spark plug. Started and ran fine. Now gonna let it sit for now and hope for the best. Thanks all
Old Apr 3, 2010 | 03:36 PM
handsome rob's Avatar
I am not sure if this would work but since it is not seating all the way you could double up on the copper washers to help it seat. The silicone will probably melt off unless it is very high temp. A key help when tapping and not wanting the filings to drop is to use something like vaseline or wax on the threads and it will bring them back out with the tap.
Old Apr 4, 2010 | 01:01 AM
All set. I did it again and it seats all way the down with no leaks. Learning experience. DON'T CROSS THREAD....thanks again
armyeng
Mar 8, 2011 05:58 PM
IDAHODISCO
Sep 6, 2009 01:19 PM
financialwiz101
Jul 12, 2009 03:11 PM
WolfPack
Feb 1, 2009 10:58 AM
BADBUZzZzZz
Jan 28, 2008 11:38 AM
