key fobs for RR P38 (2000 vintage)
Old Oct 24, 2012 | 03:56 PM
Captjohn's Avatar
Default key fobs for RR P38 (2000 vintage)
anyone got any sources for Alarm Key Fobs and key blanks.... my stealership wanted over 500 a piece for the Key Fob!!! not really willing to spend that much as im rarely locked up!!
also does any one know if the alarm reset with the ignition key in the door lock is lock unlock lock unlock????? i had the dreaded Engine Disabled error after i locked the door in Miami....alarm went off and had to get towed to the shop, but i didnt watch close enough to what they did....
Capt John
Old Oct 24, 2012 | 08:57 PM
04duxlr's Avatar
Supposedly, the dealer is the only source for key fobs for these vehicles but these guys say they can program a remote for you: Range Rover P38 Key
They are in the UK so you would need to contact them and see if they can help you.
As for the alarm disarm procedure, check this: P38A 2 hours and it's already sat on my drive, dead! - Page 2 - Land Rover Zone
Old Oct 25, 2012 | 08:01 AM
wastedincome's Avatar
I called my local dealer last week regarding getting new key and fob, price was $325
Old Oct 25, 2012 | 09:05 AM
Rovin4life's Avatar
Just use the manual key an ignore the remote for now on. It will never go into superlock or completely arm the system.
Old Nov 2, 2012 | 01:40 PM
Captjohn's Avatar
thanks all yall....but it felt pretty serious as i was stuck outside the vehicle and the alarm went off whenever i opened the door......and had the "Engine Disabled" error......
can anyone verify "lock unlock lock unlock" alarm reset from the door key????
Old Nov 2, 2012 | 09:17 PM
ChipG's Avatar
The EKA code for NA spec P38's is
4 times right
1 time left
5 times right
1 time left
5 times right
Enter it slowly
Old Nov 20, 2012 | 04:52 AM
Janifer11's Avatar
5th Gear
Only dealer has authority of febs lock, it can also change original key which help to control all the essential functions of security. Alarm system have its own system of security which cannot understand easily.
Old Nov 23, 2012 | 07:22 AM
ranewman's Avatar
My second P38 came with a fob that was badly eaten up from the battery being left in for 6 years. I sent it to Remote Key (uk), and had the fob rebuilt, programed, and a standard key done...all under $100.00, and was back in my hands in less than 2 weeks.
Old Nov 24, 2012 | 05:45 AM
Russian_Rover's Avatar
Default Does this work on all P38s??
4 times right
1 time left
5 times right
1 time left
5 times right
Enter it slowly
Does this work on all P38's?? I am searching for this code for my 1998 P38! I have to change the battery and I am worried that I might need the alarm reset!
Old Nov 24, 2012 | 07:36 AM
ChipG's Avatar
Should work on all North American spec P38's
