Labor Cost Spark Plug Wire Replacement
Old May 16, 2009 | 11:17 PM
firstcoast's Avatar
5th Gear
Smile Labor Cost Spark Plug Wire Replacement
Hello, my spark plug wires on my 99 4.6 p38 are due to be changed. I bought a replacement set of plugs and wires from Atlantic British. I was wondering what I should be expecting to pay for labor from a local shop? Also do I need to buy a intake plenum gasket for when the plugs and wires are replaced?
Old May 17, 2009 | 10:55 PM
skyguy's Avatar
I don't know where you are @ but try rovershop (member) he would know.
Old May 19, 2009 | 12:44 AM
LRScott's Avatar
The spark plugs are not that hard to replace but, just take a little time. If you do not mind getting your hand's dirty and pulling a wrench out, it may be worth doing it yourself. You can expect to pay about $75 h/r for labor, and that is usually a low rate too. I don't think you need an intake plenum gasket unless it is leaking but, I may be wrong. Do you have the BMW engine or the GEMS?
Old May 19, 2009 | 08:23 AM
firstcoast's Avatar
5th Gear
I have the bosch engine
So would 2 hours of labor be fare?
Old May 19, 2009 | 10:08 AM
LRScott's Avatar
2 hours seems reasonable but, I sure hope it doesn't take them that long.
Old May 19, 2009 | 10:42 AM
Most shops/dealers charge 4 to 5.5 hours depending on if you have secondary air injection.
A5scott
Jul 11, 2015 07:25 PM
CPDieker
Jun 6, 2012 09:36 PM
trp34
Dec 6, 2011 07:03 AM
primey
Oct 26, 2011 07:24 PM
werldcup
May 12, 2008 12:01 PM
