location of crankshaft sensor in 2000 RR 4.6 Vitesse
Old Jan 2, 2012 | 12:08 PM
Weskechi's Avatar
5th Gear
Default location of crankshaft sensor in 2000 RR 4.6 Vitesse
I want to change the Crankshaft sensor in my 2000 Range Rover but I cannot locate it in the engine. I spend several hours under the engine looking for it but just can not locate it. Any idea where it is located in the engine? Please help.
Wes
Old Jan 2, 2012 | 01:02 PM
3o'clock at the back of the engine looking from the front.
Old Jan 3, 2012 | 03:44 PM
Weskechi's Avatar
5th Gear
Smile
Thanks for your response which says: "3o'clock at the back of the engine looking from the front."
With your response, do you mean looking from underneat the engine or from the top of the engine?
Old Jan 3, 2012 | 05:04 PM
see if this photo from the RAVE helps. A P38 and a D2 have a similar engine layout, at least in the Rovers North exploded diagrams. I couldn't afford a gas cap from either.
Crank position sensors tend to be "reluctor" style, they pick up a change in the metal teeth of the ring gear whirling by just a couple of millimeters from the tip of the sensor. When replacing be sure to make a drawing of excatly where and how any spacer is oriented before taking apart. This is number one problem with replaced ones - can't crank because sensor won't trigger spark becauuse it is spaced wrong.
File Type: pdf
Old Jan 4, 2012 | 09:47 AM
Weskechi's Avatar
5th Gear
Smile
Thanks alot for the info and the pdf picture. I will let you know what happened after I get done.
EVN137
Oct 6, 2024 12:48 PM
6RedRover9
Sep 25, 2010 02:34 PM
dreone
Jan 12, 2008 01:05 PM
97vitesse
Jan 7, 2008 04:19 AM
sookoon
Nov 2, 2007 03:04 PM
