Lock out, No Start & Battery Drain
Old Jul 18, 2007 | 06:46 AM
Dopey's Avatar
6th Gear
Default Lock out, No Start & Battery Drain
Hi All
Lock out, No Start & Battery Drain, is this all fixed by Part # YWY500170 Modded RF Reciever Module?? thanks
Also is this a DIY jobby? if it is anyone know whats involved? and is there a DIY link some place
Thanks all
Old Jul 22, 2007 | 07:09 PM
esaycho's Avatar
Default RE: Lock out, No Start & Battery Drain
Battery drain is possibly the Becm being awakened by other car keyless entry remotes. No start- possibly alarm ECU not recieving the remobilization code, although I have heard at rangerovers.net about cell phone towers or high voltage line towers causing interference with the Becm that causes it or the alarm ECU, (forget which one) to lose its programming, sometimes simply moving it from that spot will cause it to work again, but I have heard one case where the dealer had to reprogram the car. Finally the lock out could be caused by the fact that the battery is drained, I do know that when the Becm recieves voltage after not having it, it will lock the doors in case it is a theft attempt. but obviously if the battery is low or dead the remote won't work. The regular key portion should unlock the drivers door, but not all of them as there is no power. Hopefully this has helped you, let me know.
DustyLBottoms
Oct 25, 2010 08:45 AM
cobbcj7
Feb 11, 2009 06:43 PM
Rustybug
Jan 31, 2009 02:53 PM
shawnjones
Apr 24, 2008 03:15 PM
kingkitesurf
Jul 28, 2007 11:54 PM
