LT230 swap question
I am in the process of gathering all the bits to swap an LT230 into my 92RRC.
I am short the bracket that bolts to the frame and that the transfer case sits on via a rubber mount.
I am led to believe that this bracket from a D1 will bolt right on. Will this same bracket from D2 fit as well? It is a bit different design and uses an entirely different rubber mount. But essentially, the outer dimension of the transfer case and frame look similar.
If anyone has a line on the D1 bracket I speak of, I would like to get my hands on it.
Thanks
Mike
Thanks
Mike
gollum
11-08-2009 07:24 PM
lugo35
04-21-2005 05:07 PM
