LT230 swap question
Old Jan 22, 2013 | 08:52 AM
5bravobravo's Avatar
Default LT230 swap question
I am in the process of gathering all the bits to swap an LT230 into my 92RRC.
I am short the bracket that bolts to the frame and that the transfer case sits on via a rubber mount.
I am led to believe that this bracket from a D1 will bolt right on. Will this same bracket from D2 fit as well? It is a bit different design and uses an entirely different rubber mount. But essentially, the outer dimension of the transfer case and frame look similar.
If anyone has a line on the D1 bracket I speak of, I would like to get my hands on it.
Thanks
Mike
Old Jan 23, 2013 | 03:32 AM
Ringo's Avatar
Trying asking this on the Disco side since they're the ones that probably have the part you are looking for.
Old Jan 23, 2013 | 08:15 AM
I found a bracket, should start the swap over in a few weeks. I'm going to open up the LT230 I picked up, inspect and reseal it first.
Thanks
bennyb43
Dec 11, 2013 08:17 AM
gollum
Nov 8, 2009 07:24 PM
extremetoy1
Jul 14, 2006 12:28 PM
lugo35
Apr 21, 2005 05:07 PM
lugo35
Apr 21, 2005 05:03 PM
