Lucky 8’s Project P38
Old Jan 13, 2013 | 05:51 PM
  #41
Looking good Justin, could have used those at ROTR lol.
Old Jan 13, 2013 | 06:09 PM
  #42
Fivespddisco's Avatar
I know I know ......
Old Jan 13, 2013 | 09:01 PM
  #43
Project update
We got a tremendous amount of things accomplished this week. A fender flare was installed, the stock exhaust has been reworked to be more off-road friendly and the transfer case has been locked. Yes you read correctly Locked with a capital L!
The front fender on the driver side was getting the most abuse from the 33in tires so we started there. The grinder made quick work of the little trimming needed on the aluminum fender.
With a little bit of adjustment to the cutouts around the body lines the flares fit the P38 fairly easy.
The D2 flares were not quite big enough to house the Nittos. We needed to stretch them another inch or so at the bottom. To do this we took a heat gun and massaged the lower corner a little bit to extend the flare out.
We are all happy with the end results even know these flares were not intended for the P38. They gave us the added room we needed to fit the larger tires and now all we have to do is trim back the sliders.
I know what you're saying all this could be avoided if we just would've stuck with 32in tires but it would not be a true Lucky8 truck unless it was on at least 33's
Exhaust and Tcase updates to follow
Old Jan 13, 2013 | 09:03 PM
  #44
I'm really curious to see how you got the TC locked on that Borg Warner, probably a few P38 owners dying for that info.
Old Jan 14, 2013 | 08:25 AM
  #45
hilltoppersx's Avatar
i dont know anyone else that owns a p38 except justin and rick. i think goose had one at some point but i believe it was confiscated after he got caught drag racing congressman around the beltway
Old Jan 14, 2013 | 10:21 AM
  #46
There are a few of them out there that get wheeled. Not as many obviously as the RRC or Disco crowd. I think though with some of the things Justin has sorted out you might see more of them popping up. Especially if the solutions to the issues to make it a good wheeler aren't super expensive.
Let's be honest a lot of the RRC/D1 are getting long in the tooth and people are going to be looking for the next Rover to replace it. No one thought that the DII would become a rig of choice either a few years back and look at it now.
Old Jan 14, 2013 | 07:38 PM
  #47
skyguy's Avatar
I didn't get a chance to measure it yet, in the shop I should have it back tomorrow or Wed. I'll measure it then. Also are those RRS wheels on the unmodified version of you rig? Do you need hub centric rings to run those?
Old Jan 14, 2013 | 09:49 PM
  #48
04duxlr's Avatar
I'm not sure why mre people don't use the P38 for wheeling. They are almost perfect for it. The wheelbase works well, fro mid 99 on the brakes and traction control are amazing, and the air suspension (yes,I'm an EAS proponent) makes for a sweet ride off road. They score a 600 on the ramp in stock form with the swaybars hooked up. The later models also have the 4 pin front diff which helps keep it going as well. When lifted, they can still easily fit in a garage (unlike a Discovery). The Bosch 4.6 in them seems to be a better motor than the ones stuck in the D2. Yes, they have some crazy electrical quirks but they all can be fixed with a little effort and it's to be expected. They are British after all. Pricewise, many are practically being given away at this point simply because paying someone to fix all of the issues they develop using new parts can be crippling, but I found with mine that most issues could be repaired pretty easily and relatively inexpensively with a little search of the various forums.
Plus there's something satisfying about thrashing a vehicle off road that had a $60k plus sticker price when it was new 15 years ago.
Old Jan 14, 2013 | 10:06 PM
  #49
Its not that sexy, but it's the first go.
Old Jan 14, 2013 | 10:08 PM
  #50
Thank you.
They are RRS wheels without any rings.
