MAP Sensors
Old Oct 22, 2013 | 08:03 PM
pjbbz's Avatar
Default MAP Sensors
Hi there
Does the 1998 4.6L p38 HSE Range Rover have a MAP sensor and if so where is it located?
Old Oct 23, 2013 | 11:38 AM
Sure, all OBD2 engines have one located on the air intake hose.
Why do you ask?
Old Oct 23, 2013 | 09:09 PM
roverguy7's Avatar
To clarify, are you asking about a Mass Air Flow Sensor, or a Manifold Absolute Pressure Sensor?
Yes to the MAFS, no to the MAP.
I'm assuming an issue with the engine has you asking this question, what exactly is going on? Any faults?
Old Oct 23, 2013 | 09:37 PM
pjbbz's Avatar
Thanks Guys for replying. I was asking becuase I wanted to know whether the Range Rover has a MAP sensor as well as MAF sensor. Clearly the don't.
The Range Rover is blowing black smoke out the exhaust upon accelerating, hence running rich. There is no engine check light on so we can assume the the oxygen sensor are ok and the injectors are ok.
What else could be wrong that will not cause the engine check light to show??
migfran
Dec 18, 2016 01:19 PM
pjbbz
Oct 23, 2013 06:14 PM
thambu21
Freelander
Feb 14, 2011 08:01 AM
dgelfuso
Oct 31, 2008 12:07 AM
Granite Disco
Sep 15, 2007 09:10 AM
