Multiple Chimes After Start
Old Sep 27, 2006 | 12:59 AM
akartis's Avatar
Default Multiple Chimes After Start
I was wondering if I could trouble someone with a question? My RR has had the coil conversion done and the EAS overide module from British Atlantic is installed. However, I still get numerous chimes after I start the vehicle. Is there some sort of directory or some thing that tells me how many chimes means what? Could this be related to the brake light and TC light staying on for a long period of time after start?
Old Sep 27, 2006 | 09:02 AM
Default RE: Multiple Chimes After Start
Can't help you with the chimes but the t/c light and brake light shouldn't stay on longer. How long has it been since you changed your brake fluid or even checked it fluid level?
A good flush might help there.
Mike
Old Sep 27, 2006 | 11:55 AM
akartis's Avatar
I checked the level and it is a little low. Very little. Would that cause the lights to come on? I will give it a good flush also since I just purchased.
Old Sep 27, 2006 | 07:15 PM
esaycho's Avatar
While it is chiming does the message center say Seatbelt Please?
Old Sep 29, 2006 | 03:38 PM
akartis's Avatar
There are only two things. The first is EAS Manual. I understand this is because the coil conversion was done and it has the override modual installed. The second is Washer fluid low.
Old Sep 29, 2006 | 04:33 PM
esaycho's Avatar
Have you filled the washer fluid up?
Old Oct 11, 2006 | 11:38 AM
akartis's Avatar
I have filled the Washer fluid.
Old Oct 12, 2006 | 09:58 PM
esaycho's Avatar
Your sensor for the Washer Fluid tank could be bad
ninjaff21
Dec 21, 2013 09:43 AM
Kingmarine
Feb 19, 2012 04:28 PM
callmehero
Dec 7, 2009 07:35 AM
Darover
Nov 6, 2009 07:35 PM
SurfRat
Oct 13, 2008 08:51 AM
