Need help! Unfreezing brake system in 89 Range Rover.
![Exclamation](https://landroverforums.com/forum/images/icons/icon4.gif)
I gather that by sheer lack of use and or storage, the brake system can freeze up over time. What I need to know is how to address the problem. Is repair a matter of flushing and bleeding the brake system? Or does it require replacing all brake lines, calipers, disk/drum rotors, pads and the brake master cylinder?
Found a decent 89 Range Rover for sale. It's well within my budget and has a professional engine rebuild as well as many other new parts and repairs. Just needs new battery and the brakes are frozen. I would like to buy the rig but not if fixing the brake system is gonna cost to much. Please help.
I think what he is referring to is just the brakes locked up from sitting a while. I specialize in restoring cars and with getting "barn finds" up and running, frozen brakes is one of the most common issues. It doesn't have anything to do with the lines or modulators (although they can be bad from sitting too.) There are two things that can cause your brakes to lock up. The first and most common (98% of the time) is that the pad/shoes rusts and corrodes to the rotor/drum. The second and least likely is that the caliper/wheel cylinder seizes up. Depending on the climate that you are in and how long the truck has been sitting you may be able to free them up by driving it a bit or towing it slowly down the road. If you can, spray the rotors and pads with WD40 or PB Blaster the day before. It it kill your pads but they probably already need changing anyway. **Note, only do this if you are towing or trailering the Rover, DO NOT drive it after spraying them. You can also pull the wheels and remove the pads. You will probably need a heavy dead blow hammer to get them off. Once you free them up you should be good to go. This method takes the most time but also allows you to drive it home when you are done. Let me know if you have any issues. I have run into this on dozens of vehicles from motorcycles to semi trucks.
blast20
09-03-2010 12:18 AM
mgabriel
08-28-2008 07:03 PM
thechapo
03-02-2008 04:33 PM
thechapo
09-26-2007 07:08 PM
