Need OBDII for Code
Old Mar 28, 2012 | 08:41 AM
georgep's Avatar
Default Need OBDII for Code
P0332 is the code and I looked it up but could not find it. Any idea
Thank you
Old Mar 28, 2012 | 09:27 AM
Mr. George,
See attached, it is a signal associated with the knock sensors, may indcaite a loose plug, or the sensor itself not torqued into block correctly. By the magic within the ECU, the knock sensors let then engine computer know to alter ignition advance, and the ECU can have each cyclinder on a separate advance timing to try to control knocks with bad fuel, etc. Passenger side.
File Type: pdf
Old Mar 30, 2012 | 06:58 PM
georgep's Avatar
Mr. George,
Great thank you. Engine is running perfect. fuel is over a year old so I dumped some Lucas Oil fuel stuff, ran it down to almost push and refilled the tank. Lets see what it does now.
Per the UltraGauge went 136 miles all type of driving and overall MPG was 19.2. The old engine was around 15 or 16 with no bottom end.
Thanks again
Photojoe4
Jun 3, 2012 12:41 AM
Street Wolf
Oct 12, 2011 12:06 PM
Todd-Squad
May 10, 2011 11:30 PM
Johnny_G
Nov 23, 2010 11:27 AM
hanivw
Jan 25, 2008 12:51 PM
