No dash lights, electronics, won't turn over
Old Feb 17, 2012 | 07:50 PM
zombiedisco's Avatar
Default No dash lights, electronics, won't turn over
Well, my beloved 92 classic is giving me problems. I recently had to replace the wiper motor and it took some time (a few hours here a few there) due to my schedule. I also replaced the relay. got it all back together today and turn the key.... nothing. No dash lights come on, heater wont blow, windows don't work etc. Also, doesn't try to turn over or engage the starter. However, all things that aren't reliant on the ignition being on work. Overhead lights, horn etc.
Yes, the battery is good. Checked all the fuses.
I replaced the ignition (albeit with a used one) earlier this year due to the key barely working in the prior ignition.
Any direction from here would be greatly appreciated.
Old Feb 17, 2012 | 08:41 PM
Fusible cable, shown on schematic as fuse 3, but it is described as fusible cable ignition. So that would act like a fuse, but not look like a fuse. Wiring schematic older style drawing, attached.
File Type: pdf
Old Feb 17, 2012 | 08:47 PM
Thank you, the fusible links are located near the coolant reservoir correct?
Old Feb 17, 2012 | 09:11 PM
Not sure, hard to find in RAVE, older drawings are fun.
Old Feb 18, 2012 | 01:23 PM
Fusible link it was.... Thanks for all the help.
Old Jun 19, 2012 | 12:15 PM
thelatinpimp's Avatar
Where did you find it??? I have the same problem
under the hood??
Old Aug 31, 2012 | 07:34 PM
techaniz's Avatar
So, where is this thing at? I have the same problem......can't read schematics
RoverJeep
Mar 26, 2020 03:10 AM
ShortTom
Oct 19, 2013 04:46 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
pdolan1
May 21, 2008 09:20 AM
pdolan1
May 18, 2008 07:36 PM
