No Sport Mode and no Low ratio??
Old Nov 20, 2007 | 08:55 PM
olivia's Avatar
Default No Sport Mode and no Low ratio??
Hi everyone - I have lost my sport mode and low ratio!!!!!! 1995 P38 4.0
1. The left side of the shifter panel is flashing constantly.
2 . The sport mode does light up momentarily when pressed.
3. When in drive (stationary or driving) the dash shows 'Select Neutral'
4. I can only access the information center whilst stationary and in neutral.
In 'High' all is OK and smooth as normal.
I have changed out the circuit board - with no luck.
Appreciate any help
English Mike - Milwaukee
Old Nov 28, 2007 | 09:59 AM
Default RE: No Sport Mode and no Low ratio??
You will probably need to have someone with a lap top type scanner go into your ECU and check for fault codes.
Old Nov 28, 2007 | 08:42 PM
olivia's Avatar
Yep - My code reader does not reach that deep,in to the system. I managed to pick up a transmission module and a transfer case module on e-bay. Still I could have checked the solenoid valves first?? Getting cold in Milwaukee - so I am getting lazy.
Thanks for you help Mike
From English Mike. Milwaukeee
angasreid
Dec 16, 2023 07:45 AM
cmossman
Jul 19, 2010 03:06 PM
yarddawg
Dec 10, 2007 05:19 PM
olivia
Nov 20, 2007 07:41 PM
