Outside Noise from a 2005 RR HSE
Old Jul 7, 2008 | 01:46 PM
hotelmez's Avatar
6th Gear
Default Outside Noise from a 2005 RR HSE
Im not sure if it is only my truck or is this a common problem. I just bought an RR HSE 2005 last month and when i drive this in the highway it seems like i can hear the whole highway. please let me know if you are having the same problem or if there is a quick fix for this.
Old Jul 7, 2008 | 08:29 PM
roverguy7's Avatar
Default RE: Outside Noise from a 2005 RR HSE
two things to check... first off the tires, run your hand along the outter edge and see if theyre cupped, have height differences between treds, if theyre goodyears they probably are, get michilens... also, look at your windshield cowl, black plastic piece below your wipers, see if its kind of warped, and loos on the windshield at parts, if so you need a new one
Old Jul 8, 2008 | 11:37 AM
wmb's Avatar
wmb
4wd High
Do you have a rack? That can increase the wind noise level as well otherwise this generation RRshould bevery quiet...
Old Jul 9, 2008 | 12:10 PM
hotelmez's Avatar
6th Gear
No racks installed and all of the rubbers in the doors are quite soft and intact. There really is a very big difference comparing this to a car in terms of outside noise.
david4ducati
Mar 1, 2015 07:59 PM
roverboy
Dec 3, 2008 07:23 PM
rkrainak
Oct 11, 2007 09:15 PM
smithwick
Feb 27, 2007 01:53 PM
