fluid on outside of rim
Old Dec 3, 2008 | 04:24 PM
roverboy's Avatar
Default fluid on outside of rim
hello just came back home to notice some fluid on front passenger tire so I took off the tire and noticed a black piece that is under the center piecr that had a very small crack in it with fluid coming out so I checked all center pieces and the front passengerseems to have that only cover can somebody please give advice thanks.
Old Dec 3, 2008 | 04:57 PM
Disco2Guy's Avatar
Default RE: fluid on outside of rim
Pics would help. What do you mean by black piece under the center piece? Do you mean the center cap of the wheel? It's probably either brake fluid or oil from a busted hub seal.
Old Dec 3, 2008 | 05:09 PM
roverboy's Avatar
Yes I was just reading my haynes manual it is a dust cap to the hub so what do I do fo a busted hub seal?
Old Dec 3, 2008 | 05:13 PM
roverboy's Avatar
Sorry it is a busted hub seal how do I repair?
Old Dec 3, 2008 | 05:21 PM
Disco2Guy's Avatar
You'll need to post your vehicle info before we can help you. D1's and D2's are very different beasts.
Old Dec 3, 2008 | 05:26 PM
roverboy's Avatar
1996 se d1
Old Dec 3, 2008 | 05:33 PM
redhotbuzz's Avatar
This will give you an idea.....http://www.4x4wire.com/rover/mainten...heel_bearings/
Old Dec 3, 2008 | 07:23 PM
Now is the perfet time to have your wheels bearings replaced.
Go to www.atlanticbritish.com and order their DI hub repair kit x2, it is new hub seals and 2 wheel bearings, buy two kits and you will get two seals and 4 bearings.
I did this because I had a bad wheel bearing over a year ago, $120 for both kits, $60 to have the local muffler shop do the work.
hotelmez
Jul 9, 2008 12:10 PM
rkrainak
Oct 11, 2007 09:15 PM
smithwick
Feb 27, 2007 01:53 PM
