P38 auto box over heating?
Old May 27, 2007 | 12:56 AM
ant996's Avatar
4th Gear
Default P38 auto box over heating?
Got a 96 P38 Range Rover, 2.5DT BMW engine. The gear box keeps over heating, warning light keeps coming on?
This only happens when going up hill or towing our boat
Gearbox is full of ATF, fans are working?
Am i using the right ATF? or is there a special one for RR's.
thanks ant
Old May 27, 2007 | 07:06 AM
CBRmatt600's Avatar
Default RE: P38 auto box over heating?
I get that warning light once in a great while, usually on a cold or wet morning right when I start the car up. Other times on rainy days it will come on internmittently while driving. I know it's not actually overheating, something to do with water around a connector I'm assuming.
In your case if it comes on while towing however, that might be an actual problem. I'd make sure it is full of fluid, change it if necessary.
Old May 27, 2007 | 07:37 AM
The temp sensors are known to fail causing bad readings and warning lights, also the wires can get shorted and the tranny cooler can be plugged up, restricting the flow. You might also check the radiator for blockage, if there is not enough ait going thru this will over eat the tranny.
Mike
Old May 28, 2007 | 01:20 AM
ant996's Avatar
4th Gear
fluid is full in tranny and just replaced with new ATF. still over heating.
this is also causing the engine temp to go up too.
Old May 29, 2007 | 11:06 AM
If the engine temp is also rising, I would get it right to a sho with as little driving as possible, sounds like either your radiator air flow is blocked, the fans aren't working or something.
Mike
SolbergFanBoi
Mar 5, 2012 07:05 PM
les mitchell
May 14, 2008 12:22 PM
99Landrover
Mar 15, 2006 11:08 PM
budley62
Jan 24, 2006 01:28 AM
budley62
Jan 3, 2006 05:36 AM
