p38 axle seal replacement?
actually to replace the rr just take off the caliper and bracket as one assembly, lay aside and then take off the connector to the abs and take the bolts out of the axle and pull the entire axle out as an assembly. you can do the same with the front as well. Just disconnect the connector to the abs sensor.
Thanks I seen the link that lrscott posted. Do the big nut behind the wheel cap still have to come off? Don't look difficult at all actually. I know that the d1 are a different beast but changing wheel bearings on was easy. Gonna order the seals from roverparts.com tomorrow. Ill let you know how I make out. Thanks
cationmoted
10-19-2012 07:39 AM
