P38 Engine won't start after being powerwashed-Need Help
Old Apr 27, 2008 | 09:33 PM
afox04's Avatar
4th Gear
Default P38 Engine won't start after being powerwashed-Need Help
My neighbor powerwashed my 98 4.6 HSE engine. it was running fine while he did it, and even the following day. However, this morning when I came out to start, it would crank but not start. I'm guessing he got water somewhere he shouldn't, but what do I do??
Any help is greatly appreciated.
Old Apr 27, 2008 | 10:05 PM
WolfPack's Avatar
Default RE: P38 Engine won't start after being powerwashed-Need Help
First step is to take out all the relays and fuses under the panel in the hood one by one, blow out/dry off the bottoms, and replace. In my blazer I got some water in there washing out the engine bay and it caused the same problem...water got under the fuse panel, and over the rest of the day worked under a contact somewhere....a few of my relays had water under them, after a quick dry, all worked!
Old Apr 28, 2008 | 09:40 AM
afox04's Avatar
4th Gear
I checked fusebox and I have nothing that is wet under there. Any other suggestions?
Old Apr 28, 2008 | 10:13 AM
If I remember right, and I may be wrong, isn't your ECU mounted in the engine compartment? If so that will be your problem, and it will need to dry out before it will restart.
Disco Alan
Nov 21, 2014 09:21 AM
Macbeth
15
May 8, 2013 06:07 AM
cationmoted
Sep 1, 2010 05:12 PM
Ronco
Nov 29, 2008 07:51 PM
Willie 00D2
Oct 27, 2008 12:28 AM
