P38 Exterior Trim
Old Dec 19, 2012 | 09:30 AM
jayvick's Avatar
Default P38 Exterior Trim
I am trying to pop the exterior trim in the back left corner back on but it seems as if I can only get the top or bottom in but not both at the same time. Does anyone have any tips for this?
While we are on the topic does anyone know if they the trim and the front and rear bumper in parts that math the body color or if these are able to be painted and look good?
Old Jan 14, 2013 | 06:35 AM
tee51397's Avatar
Pull the plastic retainers out of the body panel first. Then insert them into the aluminum channel on the trim piece, line them back up with the body and push back in.
To get the plastic bits into the channel insert one side first then put a screw driver vertically on the other side of the channel then push down on the plastic retainer and finally use the screwdriver as a lever to guide it in. The plastic will bend then pop into the other channel so don't worry about breaking it.
xhevi
Jan 17, 2019 01:31 PM
er1c
Jul 1, 2013 07:33 PM
AuZZZie
Jun 22, 2011 09:13 AM
hollis
Mar 28, 2009 08:57 AM
russwess
Apr 23, 2006 11:15 PM
