P38 Lacking Power Turbo ?
Old Dec 26, 2017 | 04:46 AM
madbrit's Avatar
4th Gear
Default P38 Lacking Power Turbo ?
I have 1995 P38 Diesel 2.5 it has lost a lot of power, i have taken the turbo off and both the impeller and compressor fans are turning freely without any play, it is a bit sootted up though.
I have inspected all the air inlet pipes for damage and no signs of degradation of bits falling down to block air inlet
The Inter cooler & pipes are all clear
Also the bypass gate is closed and works with a bit of pressure from air line
The turbo - Manifold gasket had burned away at the top, but only around the bolt hole not the seal.
So I am now looking for the turbo vacuum boost sensor and I cant find it.
The manual all be it a 2000 model says it is on the left bulkhead, cant see it
The pipes going to the MAP sensor is ok no leaks as I understand this has some bearing on the Turbo Boost Sensor.
Anyone got any ideas, might it be something else and not turbo ??
Thanks in advance
MB
Old Dec 26, 2017 | 10:50 AM
OverRover's Avatar
The turbo boost pressure sensor is mounted on the bracket on top of the fuel filter.
LH rear or RH rear, either way just look for the fuel filter that's were it lives.
Old Dec 27, 2017 | 03:56 AM
madbrit's Avatar
4th Gear
Thanks, I thought that was the MAP sensor.
Can you tell me where you are getting all this info, what book, manual are you using and where I can get it
Thanks
Graham
HGR
Oct 3, 2017 09:08 PM
Benjamin Wright
Feb 23, 2013 10:22 PM
disco202
Jan 22, 2012 09:51 PM
steve
Feb 18, 2009 12:02 AM
viper205
Jun 17, 2008 07:44 PM
