P38- Need help removing drivers door panel.
Hey guys my window works good on its way down but when i go to put it back up it crooks forward slows to a halt then goes back down on its own. Only if i guide the glass by hand will it slide right into position. Im guessing the glass is off the track and I'd like to get inside the panel. Any help with this would be appreciated
You'll have to unscrew the the inside handle/armrest and then the latch (I think there is a screw on the latch, can't remember). The rest of the door cover is held on by metal clips which will require you to pry the panel off. Be careful, you might break the plastic part of the clip if you pry to hard to fast. Good luck!
Bishop
05-31-2013 09:39 PM
