P38- Need help removing drivers door panel.
Old Feb 4, 2010 | 09:35 AM
LRRange's Avatar
4th Gear
Default P38- Need help removing drivers door panel.
Hey guys my window works good on its way down but when i go to put it back up it crooks forward slows to a halt then goes back down on its own. Only if i guide the glass by hand will it slide right into position. Im guessing the glass is off the track and I'd like to get inside the panel. Any help with this would be appreciated
Old Feb 4, 2010 | 09:28 PM
LRScott's Avatar
You'll have to unscrew the the inside handle/armrest and then the latch (I think there is a screw on the latch, can't remember). The rest of the door cover is held on by metal clips which will require you to pry the panel off. Be careful, you might break the plastic part of the clip if you pry to hard to fast. Good luck!
Old Feb 5, 2010 | 06:07 AM
Rovin4life's Avatar
needs either a regulator or adjustment. most likely a regulator.
Old Feb 27, 2020 | 09:09 AM
Disco1inOxford's Avatar
In the process of removing the back door panel to get at the latch mechanism for the door handle. Is there any trick to removing that arm rest? Very little room to work that bolt head, I need to locate the right size driver anybody know the dimensions? Thanks!
redrover75
Mar 27, 2018 09:24 AM
Bishop
May 31, 2013 09:39 PM
cationmoted
Dec 4, 2010 08:55 PM
hersrud
Oct 4, 2010 03:44 PM
2000 Disco 2 SD7
Nov 19, 2007 02:32 PM
