P38 Overheat Pt2
I believe this is the hose.
LAND ROVER PARTS - HOSE - BYPASS/THERMOSTAT - R/R P38A TO WA392225
Are you experiencing high pressure in the radiator hoses?
The stupid thing ran for 101 miles before popping the hose.
Well, if you had HG work, and for some reason there is now higher pressure in cooling system, first it found the loose clamp on the bottle. Now an older hose (assumption on my part that hose may not be new). Perhaps more hoses are in your future. Take a look at Rovers North exploded diagram: 1999-2002 Range Rover P38A Radiator, Hoses, Cooling & Heating Parts Available from RoversNorth.com
LAND ROVER PARTS - HOSE - EXPANSION TANK-PIPE P38A
Will pull the old one to check.
The head gasket was not done BUT they replaced the radiator at the dealers. I agree with the Higher Pressure. I need to make sure about the shape of teh other hoses.
peter r
12-30-2022 08:08 AM
rangeroverp38dse
07-30-2009 08:55 AM
