Random Beeping Sounds
Old Jan 15, 2009 | 12:05 AM
mlshelton's Avatar
Default RE: Random Beeping Sounds
I get all of the above in the 4.4's also - I moved the speed setting up to 85 mph (but still get it too often traveling the parkway), the cold weather goes off at 39 degrees for me, I get a constant "check coolant level" indicator and beep in both 06 and 08 (which never replicates
itself at the dealership) and I get that strange one Luxruy mentioned too....what the hell is an "ebox fan"?
Old Jan 15, 2009 | 02:12 AM
Faymester's Avatar
... the Environmental (E) box, in the front left corner of the engine compartment. The E-box provides a protective environment for the ECM and is cooled by an electric fan. The main relay for the ECM is also located in the E-box...
source: http://en.allexperts.com/q/Land-Rove...cm-exposed.htm (very unrelated to our thread here)
Old Jan 15, 2009 | 07:02 AM
mlshelton's Avatar
I get another strange one every now and then - a long, solid (maybe 15-20 seconds) that then quitely fades out - it has occurred only in
two instances when going back into F gear from having backed up, or when turning the car off right after preceeding front or rear bumper sensors have gone off. It makes an entirely different "pitch," no idea what it is. Again, dealers had no clue either.
Old Jan 15, 2009 | 06:34 PM
4.4Range's Avatar
The bearing of the Ebox fan is what's making this buzz. You can open up the EBox and see for yourself. The little fan is located inside on the bottom of the Ebox (black box on the passenger side in your engine compartment). It's a DIY and shouldn't take too long to change.
Old Jan 15, 2009 | 07:35 PM
luxury1's Avatar
The ebox fan is really interesting! I had no idea this existed and will open it up next time it does it to "catch it in the act"
Old Jan 24, 2009 | 02:57 PM
HSEJavaBlack's Avatar
5th Gear
I went to radio shack for the replacement electric motor. Now the fan makes an incredible humming noise and the wooshing air from under the glove box. I am ready to get a new motor, being careful tofind one thats a few hundred rpm less,after all it was only 5 bucks and twenty minutes.
Old Apr 10, 2019 | 07:53 AM
Melis61775's Avatar
I tried to go through a car wash yesterday and my horn kept beeping the whole way through then several times after I parked and shot car off... no clue why but people sure give some funny looks
TRIARII
Aug 7, 2014 11:34 PM
DiscoveryHouston
May 3, 2011 01:39 PM
luxury1
Dec 8, 2008 08:42 PM
Roverboy3766
Nov 13, 2007 07:04 PM
dgstrat
May 14, 2005 03:23 AM
