Range Rover 96 Brakes Problem
Hello all i have a problem with my brakes in a way i cant control them they dont answer to me.When i try to push them the push back my foot. And my Abs and handbrakes are always staying on if the handbrakes light turn off the foot brakes work.Pls if anyone have a suggestion Help me i REALLY NEED IT,.
Your accumulator is most likely shot. Here is the procedure for replacing it: ABS Accumulator Replacement on a Range Rover 4.0/4.6/P38
Thnx very much m8 i have only 1 question . Should i change the acumulator only or acumulator + the other part (electromotor) where he is installed?. And sometimes the electromotor works powerful and sometimes weak .when it works weak and slowly it brakes normaly and DONT push my foot back and the abs light goes .
I find you buddy very helpful you now why ia ask you becouse in the country i live doesnt exist any mechanics specializated in these jobs so my only chance is internet . I have seen that another problem with my range rover 1996 is that when i push the gas pedal the transimison chain does crack-crack how can i repair it should i register it buy a new one if you have a sugestion thnx m8..
If you hear a crack crack on acceleration or a feel/hear something slipping, it is usually the transfer case chain. Here is some info on how to remove/repair it: How To: Replace transfer case drive chain
50cool50
Oct 7, 2010 11:01 AM
