Range Rover Classic Engine Upgrade/Swap
Old Jul 1, 2007 | 02:24 PM
m3 bavaria's Avatar
4th Gear
Default Range Rover Classic Engine Upgrade/Swap
Has anyone done, or know of a Range Rover Classic engine swap? My 1995 RR Classic has 166k on the clock, and while it's still running well, I know that the inevitable is coming.
Iinstead of doing a rebuild, I'd rather upgrade to something with more power.
Anyone?
Old Jul 1, 2007 | 08:47 PM
kjj0506's Avatar
Default RE: Range Rover Classic Engine Upgrade/Swap
I just finished swapping my tired low compression ticking 180+ k 3.9 for a much lower mile much newer 4.2.
Highly recommend it. Such a nice change and it was cheap considering.
Old Jul 1, 2007 | 11:00 PM
m3 bavaria's Avatar
4th Gear
Really? That's great. I'm assuming this is the 4.2 from the LWB model?
How much of a difference did it make?
Old Jul 2, 2007 | 08:08 PM
kjj0506's Avatar
Well since mine was pretty tired and the newer ( yes LWB donor ) one is tight it is a great difference . It's no Race Rover but it is now a pleasure to drive...sounds better ( throatier ) and much smoother. It is a job , I think at a dealership it is estimated around 50 hours. I was shocked because I have done many swaps in everything from RX-7's and Beetle to muscle cars ( 69 Olds 4-4-2 , Big Block Chevelle's Mustangs , Cougars etc ) and Jeeps ( Cherokees and Grand Cherokees ) . But it is a process and time consuming so be prepared. But I am happy I did it.
Old Jul 3, 2007 | 12:51 AM
m3 bavaria's Avatar
4th Gear
That sounds great. Where did you source the engine? Did the auxilaries (radiator, ac compressor, etc) work for the 4.2, or does all of that need to be replaced too?
Old Jul 4, 2007 | 07:18 PM
kjj0506's Avatar
Everything will work but you need to swap the timing cover from the
3.9 to the 4.2 unless you prefer the serpentine belt. I used the
intake from the 3.9 as well and the exhaust manfiolds for the 4.2.
Distributor from 3.9 as well. I will be remapping the ECU after
getting a Mallory Distributor for cleaner more reliable ignition. Then
I will be done and ready for installing an LPG set up. But that is the
direction I am going. As it is now with all RR parts ( except an
electric fan in plave of the clutch fan ) I am very very very happy
Old Jul 25, 2007 | 02:07 PM
ctbrace's Avatar
i burned my motor recently, and now want an upgrade.
I've been told I can/should use the 4.6 out of the 2003+ disco's. and swap all my stuff over.
stronger motor, more power, lower miles
cost of motor around 2500 - 3000
95RoverLWB
Apr 3, 2013 08:46 AM
roverfriend
Sep 26, 2010 11:04 PM
Caribbeanrange
Apr 17, 2009 02:24 AM
OldDirt
Nov 9, 2008 03:20 AM
OldDirt
Nov 4, 2008 10:49 PM
