Range Rover & Discovery Engines - Interchangeable?
Old Dec 23, 2010 | 09:43 AM
handsome rob's Avatar
When you get there post what you see wnd we will be able to help figure it out. Hopefully it is not as bad as you think.
Old Dec 26, 2010 | 06:29 PM
sideburns's Avatar
Are you swapping out the short block? or putting a junkyard motor in it? Make sure you have the proper cam in it, orange for 4.0, red for 4.6 liter make sure the intake is the same, note the postion of the crank sensor.
Old Dec 27, 2010 | 10:52 PM
rockcity's Avatar
@sideburns - I'm just gonna put a junkyard motor in it for now. First I'm gonna try this Blue Devil sealant stuff. See if that works. Worse case, I gotta change the engine anyway. I plan to keep this thing forever. I'm going to swap the motor, and eventually do an LT1 Conversion. That will make it more reliable, and I don't have to deal with that finicky BeCM anymore.
Old Dec 28, 2010 | 05:07 PM
sideburns's Avatar
Be very careful and inspect the motor before installing, I went through a few motors before the yard send me one that would match up. If it's got miles on the new/old yard motor might want to do a quick valve job and intake gaskets while its easy.
Old Dec 29, 2010 | 06:54 AM
Chris X's Avatar
Good luck, I don't think the fix-in-a-bottle will work but I suppose no harm in trying.
sideburns makes a good point. A real good time to replace the head gasket on the junkyard motor before installation as well. Oil pan gasket if you have time, but that is relatively easy with the motor in the car.
Old Dec 29, 2010 | 05:59 PM
rockcity's Avatar
Honestly, I don't think the fix-in-a-bottle is gonna work either. But hey, what have I really got to lose... right? I'm gonna follow the instructions to the letter and keep my fingers crossed. One can only hope... If it works, I just bought myself some time to get a new engine, or even source the parts for my LT1 conversion. THAT should be fun...
Rachel Ojani
Mar 18, 2014 08:43 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
meltdowndave
Nov 27, 2009 01:57 PM
Suede
Oct 4, 2009 01:19 AM
