Range Rover p38 1997 engine does not start
Old Dec 10, 2008 | 01:37 PM
pat3d's Avatar
Default Range Rover p38 1997 engine does not start
Hello,
I have a problem on my range rover 1997. My engine doesn't want to start.
It seems like a alarm problem.
I have trrid everything I've found on the internet as advice, use the remote, to lock and unlock, use the key on the driver door to reset the alarm, etc...
The only thing that works, is to disconnect the battery, then put the key on position 2, reconnect the battery and then start the engine.
Land Rover told me that I have to change the Becm. (1800$)
Recently, I've had a cable changed in the driver door, because I couldn't open the door from the inside, the motor of the passenger window has been changed, and the switch panel where are all the switches to open the windows has been changed too.
When I got my car back, the engine was starting fine.
The only thing I have made after that, is to program the homelink. Since then, the engine refuses to start. I don't know if this is related or not.
Thanks in avance for your help.
Pat3d
Old Dec 11, 2008 | 11:56 PM
tacomatech's Avatar
Default RE: Range Rover p38 1997 engine does not start
Clear out your homelink programming and see if anything changes. Perhaps the RF signal your garage door opener uses is having some
effect on your security system.
Old Dec 12, 2008 | 02:48 AM
WolfPack's Avatar
If the system was simply dropping the key code, would it at least be saying Engine Disabled? Message displayed or not, if the BCM is working properly, all it would take is reprogramming the key in the door correct?
I had a simillar problem that turned out to be a failing key/fob. I couldnt resync the key and the BCM because the key was bad. Might want to try using the spare key, or getting a valet key (lower cost) as a test?
Just some thoughts!
Old Dec 19, 2008 | 03:58 PM
pat3d's Avatar
Hello,
Actually, it wasa badbattery. I changed it and it's working fine now.
lbsalvin
Jun 28, 2014 01:10 AM
JonCP
Feb 1, 2013 02:12 PM
JonCP
Nov 4, 2012 02:14 PM
Manumaputo
Mar 26, 2012 08:28 AM
retrac
Sep 12, 2008 03:52 AM
