Range Rover Runner Boards, Side Steps
Old Dec 22, 2011 | 10:42 AM
davidtudor1's Avatar
4wd High
Default Side Steps, Running Boards
Hi
I have found the module under dash on RH side.
We now have a CAN fault and the side steps still not working but all the DTC's have gone except U-0416-68, which is vehicle dynamics control module, signal invalid. Any ideas? Looks like the can bus circuit i presume.
Old Dec 25, 2011 | 12:59 PM
Rovin4life's Avatar
check can lines for issues. make sure there are no fault issues with anything else.
although, check the wires on the passenger side seat make sure there isn't any water intrusion.
Old Dec 27, 2011 | 06:16 AM
4wd High
Default Side steps
Hi
Yes there is a fault with the TPMS system which I believe is on the same can bus system, these both are generating faults.
The code we are getting is U-0416-68
Old Dec 27, 2011 | 06:17 AM
4wd High
Thanks for your help in this!
Old Jan 3, 2012 | 05:45 AM
4wd High
Just wondering if any more thoughts on this problem being linked to the TPMS system?
Old May 23, 2023 | 07:48 AM
David Hallworth's Avatar
I know this is a really old thread and as a rule I hate reviving threads on forums, however, my car is exhibiting exactly the same symptoms as you describe here.
I've replaced the ECU, the switch, I've checked the wiring loom for continuity and am getting nowhere.
They worked on Christmas Day, then on Boxing Day they did nothing.
Did you ever find a solution to your steps not working?
Thanks,
David.
06_fullsize
Nov 22, 2012 10:29 AM
ShortTom
Sep 8, 2010 08:39 PM
Torancis_LR
Oct 23, 2009 06:08 PM
carnut
Dec 15, 2008 03:31 PM
DiscoOn22s
Mar 17, 2008 05:17 PM
