Rover Trailer Wiring
Old 06-22-2010 | 09:30 AM
krazzz's Avatar
Default Rover Trailer Wiring
I was wondering if anybody has installed the trailer wiring kit from AB? It looks nice and simple but I'm not sure it is worth $100. A big drawback for me is that it doesn't have the round plug, it only has the flat. Has anybody installed a universal kit? Did you have any problems with your electrical after that such as the burned out bulb warning light? I found a nice universal kit for $40 that has a great plug that will accept the round or flat plugs. Its a little more work to install but I save $60 and get the dual plugs.
Old 06-22-2010 | 06:06 PM
Rovin4life's Avatar
The rover one has a seven pin one and you can buy an adaptor. Seen a few issues with the AB after a few years.
Old 06-22-2010 | 09:10 PM
krazzz's Avatar
Well I actually had a stroke of luck tonight. I bought a universal kit but when I pulled the panel to hook it up I found that the previous owner had already installed one. I tested it out and everything worked!! That doesn't happen to often.
Old 06-22-2010 | 09:37 PM
lordmorpheus's Avatar
Uh oh. That just means you are going to have bad luck on your next project. The Rover gods have to keep the luck ratio even.
(make sure the next project is something simple, so even with the mandated bad luck, it won't be too costly)
Old 06-23-2010 | 08:24 AM
krazzz's Avatar
DON'T even joke about that. I am planning on doing the head gasket this weekend if the weather holds out. Unfortunately you are right, the Rover Gods will not allow that kind of luck on two projects in a row.
Old 06-24-2010 | 06:44 AM
Rovin4life's Avatar
You could always have an earthquake.
Old 06-24-2010 | 12:25 PM
krazzz's Avatar
I actually felt the one yesterday. We are 400 miles away but it shook our building.
gruehle
07-27-2020 09:10 AM
mtr1974
02-28-2013 09:37 PM
LADEROUTE
10-14-2012 08:34 AM
wizardmagu
03-16-2010 10:08 AM
bbensten
08-05-2005 03:52 PM
Quick Reply: Rover Trailer Wiring
