rpm is high
Old Sep 6, 2009 | 05:06 PM
val's Avatar
val
Default rpm is high
i have 1999 range rover 4.0 se rpm is up to 1900 in park position any suggestion. thank you
Old Sep 7, 2009 | 10:56 PM
LRScott's Avatar
might be the tps sensor. Is the idle ever erratic?
Old Sep 8, 2009 | 08:35 AM
Check and clean your t/body, your idle control unit and check for vacuum leaks.
Old Sep 8, 2009 | 11:29 AM
val's Avatar
val
Default rpm
its start with 1200 rpm then i cleaned idole controle units and everything aroun then rpm went to 1900-2000 rpm also while engine run i tried disconect idole sensor and something wright nex to it and nothing happen like its not working should i just buy new sensor?
omarica7
Mar 11, 2014 08:12 AM
gunny
Mar 2, 2011 07:43 AM
val
Oct 1, 2009 01:01 AM
spencerfre
Aug 15, 2008 11:55 PM
