suspension lift
RE: suspension lift
Thanks after posting I located a shop here, they said that new spring 2" over stock and strong than the stock springs , would work good, but you may still have some rubbing a 2" body lift or cutting would also make it work good. Now I'll just have to make this happen and see what would look and work better.
RE: suspension lift
You are going to need at least a 3" inch lift to be comfortable with those tires. I have a 2" lift w/265 75 R16's and get minor rubbing occasionally while offroading (none on road). A 3 " lift (from Rovertym for best results height wise) will let you slide those pups in (no trimming). You WILL have a dramatic loss of power with those big meats on there - you have a 3.5 liter I believe, my 3.9 took a hit with the tires when I upsized...
