suspension lift
Old Mar 14, 2007 | 05:47 PM
ramwheel's Avatar
Default suspension lift
trying to get some good info on what type a lift I would need. I have a 1993 range rover needs new shoes pretty bad, have a set of 285X70X16. Need to know how much of a lift I would need or maybe down size to265X70X16 and make life easier and cheaper.
Old Mar 14, 2007 | 10:31 PM
Default RE: suspension lift
I would think a 2" lift would be more then enough for those tires.
If you want to get some info from a shop, get back to me and I'll send you a name and number to call, they can give you the exact info.
Mike
Old Mar 15, 2007 | 12:35 AM
ramwheel's Avatar
Thanks after posting I located a shop here, they said that new spring 2" over stock and strong than the stock springs , would work good, but you may still have some rubbing a 2" body lift or cutting would also make it work good. Now I'll just have to make this happen and see what would look and work better.
Old Mar 24, 2007 | 05:27 PM
nickyill's Avatar
4th Gear
You are going to need at least a 3" inch lift to be comfortable with those tires. I have a 2" lift w/265 75 R16's and get minor rubbing occasionally while offroading (none on road). A 3 " lift (from Rovertym for best results height wise) will let you slide those pups in (no trimming). You WILL have a dramatic loss of power with those big meats on there - you have a 3.5 liter I believe, my 3.9 took a hit with the tires when I upsized...
ljdiscovery
Feb 13, 2016 11:21 PM
Emperor_MA
Jun 15, 2011 11:21 AM
LRDISCO
Feb 1, 2008 12:04 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
