Trouble Codes 2006 Range Rover Sport
Old Aug 14, 2014 | 04:47 PM
ljdiscovery's Avatar
Default Trouble Codes 2006 Range Rover Sport
Does anyone know what these codes are or know where a complete index of codes can be found?
Range Rover Sport 2006
P0500
P0198
P0071
P0851
thanks
Old Aug 14, 2014 | 08:01 PM
roverguy7's Avatar
P0500 - Vehicle speed signal invalid - This is based off of ABS signal over HS CAN
P0198 - Engine oil temp sensor signal high - Never seen this fault on this engine, but fault could be open circuit, so I would check wiring first, sensor is mounted next to pressure sensor in the oil cooler(where the filter mounts)
P0071 - Ambient air temp sensor signal high - Seen this a few times, but not too common, seen both wiring and sensor issues. Sensor is located mounted to the back of the bumper support rail, behind the grill.
P0851 - P/N input invalid - Each time I've seen this it has been erroneous, and will clear and stay away(P0850 is a different story)
To digress, are you having any ABS issues/warnings? What does the temp display in the dash say? Any overheating issues?
Deutsch100
Oct 30, 2016 01:21 PM
Matt_Attack352
Jan 13, 2014 09:55 AM
SuperchargedV8
Oct 27, 2011 12:19 PM
nvrsetl265
Jan 15, 2008 01:59 PM
