What is a no start with 'box overheat" message
Old Mar 9, 2010 | 10:04 AM
byrona8's Avatar
Default What is a no start with 'box overheat" message
in a '01 4.6 HSE? It cranks but does not start. Thanks in advance
Old Mar 9, 2010 | 05:36 PM
Have you checked for spark yet?
Remove one spark plug, reattach the spark plug wire and have a friend crank it over while you watch for the spark plug to spark.
Old Mar 9, 2010 | 07:19 PM
handsome rob's Avatar
If you do what Spike says do not forget to ground the plug base while doing it otherwise it will not spark. I am not sure what the message means since I have never seen it. You always have to look for fuel spark and air, if one of those is missing then it will not run. If it does not have spark it could be either a coil or the CPS. If there is spark bu no fuel then it could be a relay, fuse or fuel pump. If it has no air then it is a filter or a MAF. Let us know what you find.
Old Mar 9, 2010 | 08:23 PM
krazzz's Avatar
Does it crank over?
Old Mar 10, 2010 | 06:12 AM
Rovin4life's Avatar
transfer box overheat. but its possible its an issue with becm especially since the box isn't overheated
Old Mar 10, 2010 | 06:58 AM
byrona8's Avatar
Default It cranks. Battery drain somewhere too. Guy I bought the car from
said that some kind of clunk occured when he first encountered the box overheat message. I bought it as a project. The car is low miles 75k. From what I've read there could be a lot of things. Coils, wires, BECM. I guess I have to get used to it. Just don't know where to stop. Thanks for the replies guys.
Old Mar 16, 2010 | 10:09 PM
LRScott's Avatar
We are going to need more info.... It sounds like it cranks, but is there fuel and or spark!? Does it stutter or try to start? That fault you listed could be just a low battery. Also, where are you located, USA, UK, Africa, etc... This will determine if its an immobilizer issue. Has it thrown any OBD fault codes? My first thought is the possibility of a crank shaft position sensor problem, as they seem to go out a lot on the BOSCH models.
peter r
Dec 30, 2022 08:08 AM
jycsalas
May 23, 2019 03:02 PM
jmason
Mar 12, 2013 08:08 PM
Sanriogonz
May 23, 2012 11:27 PM
range_rovin1986
Mar 29, 2007 06:43 PM
