Will wider tires fit on an '06 RR SC
Old Dec 10, 2009 | 08:02 PM
JD1200's Avatar
Default Will wider tires fit on an '06 RR SC
Hi, the stock tires on my '06 Supercharged Range Rover are 255/50/20.
I was wondering if wider tires would fit?
For example: The Supercharged Sport comes stock with 275/40/20 tires.
Will those fit?
What's the widest tire that will fit without rubbing?
Old Dec 10, 2009 | 11:30 PM
handsome rob's Avatar
The are 20 MM wider but that is only about an inch so I bet you are safe. The best way to tell is to go to a local shop and mount some up and then turn the wheels. Since they havea thinner sidewall they should definately be okay, go to Tirerack and check the specs on the different sizes in the brand that you want and it will tell you the exact section with, then measure the gap on your current tires and see of they will fit.
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
94rover
Jan 18, 2010 11:21 AM
Roman Bronze
Tires
Oct 7, 2008 08:14 AM
fanatic516
Aug 17, 2007 11:17 AM
